Hanspi Geschrieben 20. August 2005 Share Geschrieben 20. August 2005 Hi RX-ler als frischgebackener Besitzer eines RX 300 und neuer Forum Teilnehmer erlaube ich mir euch Experten eine einfache Frage zu stellen. Ich möchte meine neu erstandene Handyhalterung einbauen und muss dazu die Abdeckung um den Schalthebel entfernen - wie macht man das ohne bleibende Schäden zu hinterlassen? Danke für den Tip, eine bildliche Darstellung oder ein online Manual Gruss Hanspi 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
p.k.blaauw Geschrieben 20. August 2005 Share Geschrieben 20. August 2005 Ok i just did a 2005 rx 330 what this mod does is it lets you dial the phone off the nav screen while your driving. It doesnt screw up nav at all. Start with bezel around shifter pull it up starting at bottom left corner you dont need to use any tool for this just your nails. Once that is removed the panel with the cig lighter and heated seats is next pull it towards you two clips holding it in. disconnect wires running to that panel.Next below radio you will see two gold 10mm bolts remove those. Put your head down by the shifter and look up in to cavity below vol and tunning knob you will see two more gold bolts they have to be removed make sure you dont drop these cause if you do there gone.Take all cd's out of changer. Remove radio by pulling it straight out there is four clips holding it in. Remove all wires and two antennas. Place radio in safe place.Once radio is out look into the top of cavety again you will see two gold bolts facing up remove them now you are ready to pull nav screen out there is four clips holding that in also. Get a old t shirt to rap around the nav assembly so you dont scratch anything. OK if you got this far congrats. Get in passenger side seat look at back of nav display you will see a bunch pastel colored wires the one you are looking for is the wire that is all the way to bottom left of the left plug light blue or baby blue cut that wire leave a little room on each side of wire so you can tape each side. Now you put it back together and you are all done. I hope this helps you guys. Good luck!!! Von U.S. Forum http://us.lexusownersclub.com/forums/lofiv...php/t13892.html 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
p.k.blaauw Geschrieben 20. August 2005 Share Geschrieben 20. August 2005 Aber auch für RX330. http://www.carstereohelp.com/stereoremovalLexusRX330Str.htm Mit Bilder. 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
