Ozy Geschrieben 18. Oktober 2012 Share Geschrieben 18. Oktober 2012 (bearbeitet) Entschuldigung für mein Deutsch! :) Ich werde in Englisch schreiben, weil es so leicht ist, und viele werden auch verstehen, und diejenigen, die nicht mit einem Google Translator genau wie ich für diesen Satz. --- --- --- c/p LOC.co.uk http://www.lexusowne...showtopic=79145 1. contact P & P Auto Services 2. buy DPF emulator (info by P&Pauto) emulator don't work with any kind of chip-box, remove chip-box or will be new hp fuel pump needed. 3. remove DPF and all sensors attached fit custom downpipe or empty DPF housing but don't forget to weld all sensors holes if you're gonna put empty/ free-flow DPF back. 4. remove 5th fuel injector line but leave 5th injector connector in place you'll need the same thread screw on top of the fuel pump to block the 5th injector fuel line. fuel line is attached on injector by plastic-click-mechanism, you will need just to unlock it with fingers. 5. bypass EGR valve here are few topics about it but find ULISSE's one and only true topic with right way procedure. block EGR hole on exhaust manifold, fit pipe-holding 25mm on cold-pipe, connect from that FMIC cold-pipe air into EGR 6. remove dual-cat (fit 2,3" / 60mm pipe) cat doesn't have any purpose on diesel engines. why factory install them? google it. 7. rear silencer is free-flow only on high throttle (flap system) so you can decide what to do (different sound by few types) I put Y-splitter and on both sides (L & R) free-flow silencers car runs much much better and consumption is lower. with those mods he passes the MOT eko-test. sound on iphone is recorded with high levels domination, IRL is little bit more lower sound noticed. http://www.youtube.com/watch?v=KkX0lFGHilc Alles Gute! bearbeitet 18. Oktober 2012 von Ozy 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
Ozy Geschrieben 24. Oktober 2012 Autor Share Geschrieben 24. Oktober 2012 :germ: 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
Guest-Rehlein Geschrieben 24. Oktober 2012 Share Geschrieben 24. Oktober 2012 Great sound. :thumbup: The exhaust of my IS 220 D was made by Fa. individual exhaust from Bergheim (Germany) and sounds like the exhaust in the video. Rehlein 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
Ozy Geschrieben 25. Oktober 2012 Autor Share Geschrieben 25. Oktober 2012 video bitte! :) 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
