The Four Thirty Nostalgia Thread
New
XS Engineering's SC430 Turbo
Das Kleingedruckte: XS Engineering-2003 Lexus SC430 Turbo.. (Engine) Engine Code : 3UZ-FE Type : V8, aluminum block and heads Engine Management Modifications : HKS F-Con V-pro (hard wired), high volume fuel pump, 600cc injectors x 8 Displacement : 4338cc Bore & Stroke : 91.5mm x 82.5mm Compresion Ratio : 9.5:1 Horsepower : 460whp (535bhp) Torque : 442ft/lbs Redline : 7000rpm (Drivetrain) Layout : Longitudinal front engine, RWD Transmision : Level 10 built with custom clutch packs, Level 10 torque converter, XS Engineering valve body modifications, XS Enigneering custom transmision oil cooler Differentials : TRD 1.5way LSD (Suspension) Front : Tom's coilovers Rear : Tom's coilovers (Brakes) Front : Brembo 355mm rotor, Brembo F50 4-pisotn caliper, Motul RBF600 fueid Rear : Brembo crossdrilled rotors, Porterfield pads (Wheels & Tires) Wheels : DTM Kruez 20 x 9F, 20 x 10.5R Tires : Pirelli P-Zero Assymetrico 245/35/20F, 285/30/20R (Exterior) Blitz carbon lower lip, XS Engineering modified factory bumper for front mounted intercooler (Interior) Factory Lexus leather, navigation system, & Mark Levinson stereo
Link zu diesem Kommentar
Auf anderen Seiten teilen
Internationale Sondermodelle, Beitrag auf "clublexus.com"
From one car to 100 to 600, Lexus produced some very nicely appointed luxury roadsters from 2002-2010 and had a great run combining class with sport and setting the pace with uncompromised ratings throughout the years. Some of the special edition, limited production cars had and used materials and parts never seen on another SC430 which made them extra special. Now that the SC430 is no longer produced, those cars and their parts will surely fetch a premium at your local dealership.
2002 Neiman Marcus Thundercloud Metallic on Pimento Called “Silver Belle” on Candy Cane Interior 100 Produced
2004-2009 Pebble Beach Editions
2004 Azure Pearl Blue on Ecru/Black 400 Produced
2005 Black Diamond on Pimento 600 Produced
2006 Tigereye Mica Pearl on Camel 500 Produced
2007 Starfire Pearl on Pimento 400 Produced
2008 Smoky Granite Mica on Ecru/Camel 360 Produced
2009 Mercury Metallic on Ecru/Black 300 Produced
2010 Eternal Jewel Edition 100 Produced (Japan Only, right hand drive)
Ausführlichere Informationen: http://www.clublexus.com/forums/sc-430/525817-the-definitive-sc430-special-edition-thread-9.html#post8240537
bearbeitet von New
Wäre es nicht besser, hier bei uns im LOC nur den Link zum originalen Text plus einen kurzen Textanreisser reinzustellen?
Solche ellenlangen Quotes als komplette Kopien anderer Webseiten lesen sich nicht nicht sonderlich gut, ganz davon abgesehen von geltenden Copyright- und Urheberrechtsbestimmungen. Man darf im Allgemeinen keine kompletten Texte von anderswo übernehmen, ohne das schriftliche Einverständnis des Autors einzuholen.
Danke für den Hinweis. Ich bin zunächst davon ausgegangen, dass bei 169 vorangegangenen Postings in diesem Thread der Einfachheit halber eine "Ausnahme" kein Problem darstellt ;)
Unabhängig davon ist das Urheberrecht nur ab einer gewissen Schöpfungshöhe zu schützen; wird diese nicht erreicht, gilt Gemeinfreiheit. Es ist davon auszugehen, dass 90 bis 95 % aller Beiträge in Foren diese Schöpfungshöhe nicht erreichen und daher auch keinen urheberrechtlichen Schutz genießen. Aber das sei ein anderes Thema für einen anderen Ort. Letztlich einzelfallabhängig.
Voriger Beitrag wurde entsprechend angepasst.
Gast
Auf dieses Thema antworten...
