Boergy Geschrieben 1. Dezember 2007 Share Geschrieben 1. Dezember 2007 (bearbeitet) Hy! Bissl auf Brembo gestöbert und fündig geworden! Es gibt: Sport Brakes (Cars) This is the basic line of the High Performance Brake Systems program. It is a braking system consisting of an integral disc, available drilled or slotted, and a complete set of high performance brake pads. The Sport Line products can also be sold as separate components. The Brembo Sport discs are premium OEM replacement units that meet or exceed all vehicle manufacturers’ specifications and tolerances. They are fully compatible with stock calipers wheels and other chassis components, easily mounting onto the vehicle. The brake discs are built in high carbon cast iron and they are available either drilled or slotted. The brake discs are then plated for corrosion resistance and for a bold, aggressive appearance. Most sport disc applications are ABE approved, a TÜV certification granted by the German Ministry of Transport. Brembo has obtained this certification due to the wholly-owned and operated integrated foundry and production process that is implemented worldwide. Sport pads come with R90 approval according to the EU requirements. Gran Turismo Brakes (Cars) This line is dedicated to the most demanding customers.This braking system originates from the Racing components, consisting of a ventilated, integral or composite disc, available drilled or slotted, 4, 6 and 8 piston aluminium calipers, a complete set of high performance brake pads, metal braid tubes and high quality small parts. Please remember that in the European Community, Gran Turismo products may only be used in racing and on private roads, unless you have obtained a new approval in compliance with directive 98/12/EC. Die bestehen aus: Mehr Infos auf der Homepage von Brembo Es gibt auch für div. Andere Lexen Bremsanlagen Zubehör, einfach mal reinschaun :ph34r: greets Boergsn bearbeitet 2. Dezember 2007 von Boergy 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
Oskar Baumann Geschrieben 1. Dezember 2007 Share Geschrieben 1. Dezember 2007 Danke für die Info , Boergy :shocking: 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
cardinal Geschrieben 1. Dezember 2007 Share Geschrieben 1. Dezember 2007 Cooles Equipment, aber leider --> Please remember that in the European Community, Gran Turismo products may only be used in racing and on private roads, unless you have obtained a new approval in compliance with directive 98/12/EC. :shocking: 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
Boergy Geschrieben 2. Dezember 2007 Autor Share Geschrieben 2. Dezember 2007 Cooles Equipment, aber leider --> Please remember that in the European Community, Gran Turismo products may only be used in racing and on private roads, unless you have obtained a new approval in compliance with directive 98/12/EC. ;) Ok..das is ja die große Bremsanlage, die kostet sicher ein Vermögen :shocking: Die anderen Scheiben (Sport Brakes) gehen, oder? Mann müsste halt mal beim TÜV anfragen, Brembo Produkte is ja kein 0815 Ding vom Markt. Sonst würds noch APR geben, aber auch nur fürn Ring. Ned so einfach mit den Japanern :) Alles was gut is, gibts ohne TÜV. greets Boergsn 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
Boergy Geschrieben 2. Dezember 2007 Autor Share Geschrieben 2. Dezember 2007 (bearbeitet) Hy! StopTech gibts auch noch, teils mit TÜV Zeugs, müsste man mal Fragen was es gibt usw... Big Brake Igling (Near Munich) +49 (0) 8241 997261 Die führen auch Stahlflexbremsleitungen für den SC430! :shocking: auf Ebay um 124 Dollar! Dann gibts noch Rotor-Works Bremsscheiben um 200 Dollar Gibts echt schöne Sachen für den SC, mal bei Brembo anfragen wegen den Sport-Scheiben, dazu gute Beläge und ganz wichtig, die Stahlflexleitungen! (die gelten in Ö als Austauschteil, da es was verbessert, so wie Sportdämpfer, daher Eintragungsfrei!, is das in D auch so? bzw sind doch Serie ;) ) greets Boergsn bearbeitet 2. Dezember 2007 von Boergy 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
koka Geschrieben 2. Dezember 2007 Share Geschrieben 2. Dezember 2007 nee leider ist es hier nicht so, es sei den die haben eine ABE. alles muss man hier eintragen. kenn das vom mazda. :sweat: 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
Boergy Geschrieben 2. Dezember 2007 Autor Share Geschrieben 2. Dezember 2007 nee leider ist es hier nicht so, es sei den die haben eine ABE. alles muss man hier eintragen. kenn das vom mazda. :sweat: Bei StopTech gibts auch Papiere, einfach mal anfragen, kostet ja nichts :pooh: dann weiß man mehr. Ich habbei den Goodridge Dekra Papiere und muss diese nicht eintragen lassen. greets Boergsn 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
IS 200 in Le Geschrieben 3. Dezember 2007 Share Geschrieben 3. Dezember 2007 ;) ab nach essen, da sind die leute da. redet mit ihnen. nicht alles ist in den katalogen :thumbup: 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
Raph Geschrieben 5. Januar 2008 Share Geschrieben 5. Januar 2008 nee leider ist es hier nicht so, es sei den die haben eine ABE. alles muss man hier eintragen. kenn das vom mazda. :naughty: Altes Thread,muß aber was dazu sagen Wenn du Bremsleitungen (Stahlflex) von Goodridge kaufst (gibts für alle fahzeugen,auch spezial anfertigungen..hab welche für mein Mitsu(andere Bremszangen u scheben verbaut) ..kosten 130 eurs) ist einen gutachten von der Dekra dabei .. es muß lediglich vom Fach Werkstatt eingebaut und bestätigt werden(Werkstatt Stempel) und nachher kann man die beim Tüv eintragen lassen . meine Goodridge Stahlflex leitungen hab ich bei www.go-performance.de gekauft.. die können leitungen für nen toyota/lexus bestimmt bestellen. Hab selbst solche Leitungen beim mehreren Fahrzeugen verbaut und hab immer nur positives feedback bekommen. Die werde ich auch nochmal verbauen. 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
