johnydeil Geschrieben 9. August 2011 Share Geschrieben 9. August 2011 Falls jemand Interesse hat, hier die Entschlüsselung der Fehlerdiagnose: DTC Error Codes Lexus Specific Trouble Codes P1100 BARO Sensor Circuit Malfunction P1120 Accelerator Pedal Position Sensor Circuit Malfunction P1121 Accelerator Pedal Position Sensor Range/Performance Problem P1125 Throttle Control Motor Circuit Malfunction P1126 Magnetic Clutch Circuit Malfunction P1127 ECTS Actuator Power Source Circuit Malfunction P1128 Throttle Control Motor Lock Malfunction P1129 Electronic Throttle Control System P1130 Air/Fuel Ratio Sensor Circuit Range/Performance Malfunction (Bank 1 Sensor 1) P1133 Air/Fuel Ratio Sensor Circuit Response Malfunction (Bank 1 Sensor 1) P1135 Air/Fuel Ratio Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) P1150 Air/Fuel Ratio Sensor Circuit Range/Performance Malfunction (Bank 2 Sensor 1) P1153 Air/Fuel Ratio Sensor Circuit Response Malfunction (Bank 2 Sensor 1) P1155 Air/Fuel Ratio Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) P1200 Fuel Pump Relay/ECU Circuit Malfunction P1300 Igniter Circuit Malfunction (Bank 1 Or No. 1) P1305 Igniter Circuit Malfunction, (Bank 2 Or No. 2) P1310 Igniter Circuit Malfunction (No. 3) P1315 Igniter Circuit Malfunction (No. 4) P1320 Igniter Circuit Malfunction (No. 5) P1325 Igniter Circuit Malfunction (No. 6) P1330 Igniter Circuit Malfunction (No. 7) P1335 CKP Sensor Circuit Malfunction During Engine Running P1340 Igniter Circuit Malfunction (No. 8 ) P1345 VVT Sensor Circuit Malfunction (Bank 1) P1346 VVT Sensor Rang/Performance Problem (Bank 1) P1349 VVT System Malfunction (Bank 1) P1350 VVT Sensor Circuit Malfunction (Bank 2) P1351 VVT Sensor Range/Performance Problem (Bank 2) P1354 VVT System Malfunction (Bank 2) P1400 Sub-TP Sensor Malfunction P1401 Sub-TP Sensor Range/Performance P1410 EGR Valve Position Sensor Circuit Malfunction P1411 EGR Valve Position Sensor Circuit Range/Performance Malfunction P1500 Starter Signal Circuit Malfunction P1520 Stop Lamp Switch Malfunction P1565 Cruise Control Main Switch Circuit Malfunction P1566 Cruise Control Main Switch Circuit Malfunction P1600 ECM BATT Malfunction P1605 Knock Control CPU Malfunction P1633 ECM Malfunction (ETCS Circuit) P1645 Body ECU Malfunction P1656 OCV Circuit Malfunction (Bank 1) P1663 OCV Circuit Malfunction (Bank 2) P1780 PNP Switch Malfunction B2785 Ignition Switch On Malfunction (Immobilizer System) B2786 Ignition Switch Off Malfunction (Immobilizer System) B2785 Ignition Switch On Malfunction (Immobilizer System) B2791 Key Unlock Warning Switch Malfunction (Immobilizer System) B2795 Unmatch Key Code (Immobilizer System) B2796 No Communication In Immobilizer System B2797 Communication Malfunction No. 1 (Immobilizer System) B2798 Communication Malfunction No. 2 (Immobilizer System) 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
johnydeil Geschrieben 9. August 2011 Share Geschrieben 9. August 2011 Warnton des Sicherheitgurtes aus und- einschalten (wenn nicht angeschnallt) Motor starten, Kilometerzähler auf ODO stellen und den Knopf (zum nullen beim Trip) drucken und so lange halten, bis "unangeschnallt" in den Mittelkonsole 20 mal blinkt, danach ohne den knopf los zu lassen gürtel anschnallen. Auf dem Display erscheint menü zur Steuerung des Signals, mit demselben Knopf zwischen b und off umstellen. 1 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
johnydeil Geschrieben 9. August 2011 Share Geschrieben 9. August 2011 Farbcode für Lexus: 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
johnydeil Geschrieben 9. August 2011 Share Geschrieben 9. August 2011 (bearbeitet) und weiter gehts :) wenn man auf dem Schlüssel die Knöpfe "auf" und "zu" gleichzeitig betätigt, ändert sich die Einstellung der Zentralverriegelung (nur Fahrertür auf, oder alle Türen auf) bearbeitet 9. August 2011 von johnydeil 1 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
johnydeil Geschrieben 9. August 2011 Share Geschrieben 9. August 2011 (bearbeitet) und noch eins :) Mikrofonempfindlichkeit der Freisprechanlage einstellen: bei laufendem Motor die Taste INFO halten - gleichzeitig 3 mal das Standlicht ein- und ausschalten dadurch wird ein Menü eingeblendet(dasselbe wie beim klicken auf die Ecken im DISP modus), dort kann man die Einstellungen vornehmen. Anschließend die "DISP" taste 3 Sekunden lang halten um die Einstellungen zu beenden. Navi-Display schaltet sich neu ein bearbeitet 10. August 2011 von johnydeil 1 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
johnydeil Geschrieben 9. August 2011 Share Geschrieben 9. August 2011 Interne Updates Bezeichnungen für Lexus 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
Miro24 Geschrieben 10. August 2011 Share Geschrieben 10. August 2011 Gibts ne Möglichkeit nach einem (selbstgemachten) Ölwechsel den internen Zähler zurückzusetzen? 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
johnydeil Geschrieben 10. August 2011 Share Geschrieben 10. August 2011 (bearbeitet) Ja, den ODO Taster (Kilometerzähler) festhalten, Zündung aus, ohne los zu lassen Zündung wieder an, solange warten bis die "------" verschwinden und "000000" erscheinen. Dies ist auch im Handbuch beschrieben im Kapitel (Wartung selbst durchführen) bearbeitet 10. August 2011 von johnydeil 1 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
Sportgleiter Geschrieben 14. August 2011 Share Geschrieben 14. August 2011 Warnton des Sicherheitgurtes aus und- einschalten (wenn nicht angeschnallt) Motor starten, Kilometerzähler auf ODO stellen und den Knopf (zum nullen beim Trip) drucken und so lange halten, bis "unangeschnallt" in den Mittelkonsole 20 mal blinkt, danach ohne den knopf los zu lassen gürtel anschnallen. Auf dem Display erscheint menü zur Steuerung des Signals, mit demselben Knopf zwischen b und off umstellen. funktioniert das bei jedem bzw beim 250er? hab das vorhin probiert, jedoch ohne erfolg. muss es genau 20mal blinken, od ab 20mal blinken? 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
Spawnilein Geschrieben 15. August 2011 Share Geschrieben 15. August 2011 Das geht auch einfacher und steht glaub ich sogar im Handbuch ... Taste für Traktionskontrolle 1x drücken ... dann nochmal drücken und halten bis Piepton ... dann bleibt auch alles aus bis zum nächsten Start oder bis man wieder draufdrückt ... hab ich im Winter auf ner großen zugeschneiteten Fläche ausprobiert :clap: Ach weil es mir gerade wieder einfällt, ging leider nicht :( Beim ersten mal drücken geht die Lampe an wenn ich dann wieder drücke und festhalte, egal wie lange geht einfach nur die Lampe aus und nichts passiert :( 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
Gufera Geschrieben 15. August 2011 Share Geschrieben 15. August 2011 Ach weil es mir gerade wieder einfällt, ging leider nicht :( Beim ersten mal drücken geht die Lampe an wenn ich dann wieder drücke und festhalte, egal wie lange geht einfach nur die Lampe aus und nichts passiert :( Dann besitzt du sicher einen IS250 welcher in den ersten zwei Jahren gebaut wurde. :g: 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
Spawnilein Geschrieben 15. August 2011 Share Geschrieben 15. August 2011 Bingo, 06er Erstzulassung :( 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
ccc Geschrieben 15. August 2011 Share Geschrieben 15. August 2011 Stimmt da war was ... gleich mal auf die Liste setzen ... 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
TommyStyles Geschrieben 19. August 2011 Share Geschrieben 19. August 2011 Weiß auch einer vllt wie man die Fensterheber mit der Fernbedienung einstellt? zbsp das nur die fahrerseite und schiebe dach aufgeben? 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
johnydeil Geschrieben 2. Oktober 2011 Share Geschrieben 2. Oktober 2011 Warnton der Gurte: funktioniert das bei jedem bzw beim 250er? hab das vorhin probiert, jedoch ohne erfolg. muss es genau 20mal blinken, od ab 20mal blinken? Batterieklemme ab, etwas warten und wieder an... und es peepst ab 20km/h wenn nicht angeschnallt. 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
lex-golf Geschrieben 3. Oktober 2011 Share Geschrieben 3. Oktober 2011 Richtig, und das neu programieren alles anderen Einstellungen kommt auch noch dazu ;) 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
p.k.blaauw Geschrieben 3. Oktober 2011 Share Geschrieben 3. Oktober 2011 Weiß auch einer vllt wie man die Fensterheber mit der Fernbedienung einstellt? zbsp das nur die fahrerseite und schiebe dach aufgeben? Ist standard, nur länger drücken :blink: 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
johnydeil Geschrieben 3. Oktober 2011 Share Geschrieben 3. Oktober 2011 Richtig, und das neu programieren alles anderen Einstellungen kommt auch noch dazu ;) Bei mir war es nicht so, bis auf die letzten Ziele in der Navigation wurde alles beibehalten. Radiosender, Sitzposition-Mamory, Ein- und Ausschalten der Innenbeleuchtung nach 10sek, kofferraum öffnen nach 3 sek. per Fernbedienung, etc. Ich habe noch keine Probleme mit den Einstellungen nach dem Abklemmen gehabt. 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
TommyStyles Geschrieben 7. Oktober 2011 Share Geschrieben 7. Oktober 2011 Ist standard, nur länger drücken :blink: stimmt garn nicht :S 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
uslex Geschrieben 7. Oktober 2011 Share Geschrieben 7. Oktober 2011 Ist standard, nur länger drücken :blink: stimmt garn nicht :S Doch: stimmt schon. Vermutlich hast du nur das Anlernen davor vergessen. Wenn es nicht angelernt ist, dann geht es natürlich nicht. 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
TommyStyles Geschrieben 10. Oktober 2011 Share Geschrieben 10. Oktober 2011 wie kann ich sie den anlernen will nicht das alles auf geht ist ja blöd 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
uslex Geschrieben 10. Oktober 2011 Share Geschrieben 10. Oktober 2011 wie kann ich sie den anlernen will nicht das alles auf geht ist ja blöd Ich klaue die Anleitung bei Gufera: die Fensterheber müssen mit dem schalter an der jeweiligen tür nach oben und unten gefahren werden und dann einige sekunden in der endstellung der schalter weiter betätigt bleiben dann übernimmt der computer wieder die steuerung und du kannst vom fahrerplatz aus wieder das fenster steuern. beim schiebedach musst du das dach auffahren und den schalter in der endstellung weiter halten, dann fährt das schiebedach wieder zu obwohl du den schalter in der öffnungsstellung festhältst. wenn das schiebedach einmal auf und gleich wieder zugefahren ist ist es wieder angeschaltet und auch die tip funktion (antippen und das dach oder fenster fährt selbst auf oder zu) funktioniert wieder. 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
Jens_IS250 Geschrieben 10. Oktober 2011 Share Geschrieben 10. Oktober 2011 Woran könnte es liegen, wenn die Fenster während des Öffnens mittels Fernbedienung mehrmals mittendrin stoppen? Ist dann eventuell die Batterie der Fernbedienung zu schwach oder kann sonst etwas das Signal gestört haben? 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
p.k.blaauw Geschrieben 11. Oktober 2011 Share Geschrieben 11. Oktober 2011 Fang mal an mit neue Batterie :unsure: 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
Faeen Geschrieben 20. Oktober 2011 Share Geschrieben 20. Oktober 2011 Kennt vllt jemand noch ein verstecktes munü wo man alles einstellen kann, wie zb bei öffnen vom auto Standlicht/Nebelscheinwerfer angehen, oder das bei antippen von Blinker er 3 mal blinkt??? :g: :g: :g: hab in sufu nix gefunden. 0 Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen More sharing options...
